Hello everyone
I want to write C program to do following task.
first blink LED,
If LED is blinking than do task for motor start, forward , backword , stop
if motor is working , display message '' motor working " on LCD
I have written program individually for each task Now I want to combine all in one program. so I try to make program its incomplete program i need help in main function . I am confused on how to do all in main function.
first blink LED,
Code:
#include <REG51.h> // Header file of AT89c51
#define display_port P2 //Data pins connected to port 2 on microcontroller
#define LED P1 // LED is connected to port P1
#define LED_ON 0xff // LED ON
#define LED_OFF 0x00 // LED OFF
//motor connection
sbit L293D_pin_1 = P3^0; // pin_1 connected to P3^0
sbit L293D_pin_2 = P3^1; // pin_2 connected to P3^0
sbit L293D_E = P3^2; // pin_E connected to P3^0
// LCD pin connection
sbit rs = P2^0; //RS pin connected to pin 2 of port 3
sbit rw = P2^1; // RW pin connected to pin 3 of port 3
sbit e = P2^2; //E pin connected to pin 4 of port 3
// delay function for LED
void LED_delay (unsigned int i)
unsigned int j;
for (i = 0; i < 40000; i++);
// Delay function for LCD
void LCD_delay(unsigned int time) // Function for creating delay in milliseconds.
unsigned j,l ;
for(j=0;j<time;j++)
for(l=0;l<1275;l++);
// Delay function for Motor
void Motor_delay()
unsigned int m,n,k;
for(m=0;m<0x20;m++)
for(n=0;n<255;n++)
for(k=0;k<255;k++);
void rotate_f()
L293D_pin_1 = 1; //Make positive of motor 1
L293D_pin_2 = 0; //Make negative of motor 0
L293D_E = 1; //Enable L293D
void rotate_b()
L293D_pin_1 = 0; //Make positive of motor 0
L293D_pin_2 = 1; //Make negative of motor 1
void breaks()
L293D_E = 0; //Disable L293D
void lcd_cmd(unsigned char command) //Function to send command instruction to LCD
display_port = command;
rs= 0;
rw=0;
e=1;
msdelay(1);
e=0;
void lcd_data(unsigned char disp_data) //Function to send display data to LCD
display_port = disp_data;
rs= 1;
rw=0;
e=1;
msdelay(1);
e=0;
void lcd_init() //Function to prepare the LCD and get it ready
lcd_cmd(0x38); // for using 2 lines and 5X7 matrix of LCD
msdelay(10);
lcd_cmd(0x0c); // turn display ON, cursor blinking
msdelay(10);
lcd_cmd(0x01); //clear screen
msdelay(10);
lcd_cmd(0x81); // bring cursor to position 1 of line 1
msdelay(10);
void main()
LED = LED_ON;
LED_delay(500);
LED = LED_OFF;
LED_delay(5000);
LED = LED_OFF;
rotate_f(); //Run forward
motor_delay(); //Some delay
breaks(); //Stop
rotate_b(); //Run Backwards
breaks(); //Stop
unsigned char a[15]="motor working"; //string of 14 characters with a null terminator.
int p=0;
lcd_init();
while(a[p] != '\0') // searching the null terminator in the sentence
lcd_data(a[p]);
p++;
LCD_delay(50);
