I'v been having repeat issue over several months and I can't think of what to try next.
I work in the IT department of a medium-ish sized company with almost 40 retail locations across a quarter of the state. Recently, after a few break-ins we were authorized to install a fairly basic security camera system in our stores. Specifically it is a Night Owl NVR (Network Video Recorder) with 4-8 cameras per store. We can view the systems remotely and while not exactly top of the line, they work fairly well.
Ok, most of them work well. We have one location who has has repeated issues with the Hard Drive (1Tb = 1 Week of recorded history). About every three weeks (never less than two, once just over a month) the Hard Drive fails. Over time we have replaced the NVR with a repaired one from the company, a brand new one, and even swapped out with one from another store that had been working for several months without issue. Each one of these, once placed at our trouble store, has a HDD failure in just under a month.
Physically the NVR is located in an office environment, no excessive heat/cold, inside a locked network box (sheet steel, bolted to the wall).
Originally we had this unit plugged into a battery backup/surge protector, but per the manufacturers recommendation we moved it to a dedicated power outlet. After a few more instances of this failure, they suggested an electrical line conditioner, which we installed.
None of this seems to have any effect over time. Sometimes, if we power the NVR down and do a full software re-install it will fix the problem for a few weeks. Other times, the HDD has crashed and is fully dead.
During a crash or HDD fail, the cameras still broadcast. There is a basic desktop PC, plugged into a different outlet, in the same office that doesn't exhibit any issues.
I've run out of possibilities, the manufacturer has stated that they have no clue what else to try and they will continue to replace the NVR as we request them.
After using the line conditioner and the battery backup, that should have eliminated any potential electrical issues. Replacing the actual device should have dealt with any random manufacturer defect or bad equipment.
What am I missing? What else can I look at?
