Hello all,
I'd like to hear from you some suggestions on what could be causing this behavior in my multimeter. As a background, its battery (standard 9V one) leaked inside it and this required me to cleanup the board with isopropyl alcohol. When I assembled it back, it appeared to be working properly, but in a minute I could notice that, when measuring voltages, it was slowly converging to a steady measured voltage (almost a minute) instead of reaching it in a few seconds.
A friend of mine told me this might be due to existent residue of the battery chemicals still on the board. He told me that this residue might be acting as a capacitor thus causing the symptom I described. It was also suggested that I should try cleaning up the board using those ultrasound cleaners.
Does this make sense? I tried searching for this on the web, but my keywords choices always end up giving a bunch of unrelated results. Can you suggest any link or paper on this?
I really appreciate any input. Thanks in advance.
Andrei
Andrei
