Hi everyone,
My multimeter started to act weird when measuring DC voltage. All readings are way higher than expected. I tested a few sources that I'm reasonably sure about and the results are way off:
- AA battery 1.5V - reading is 21V
- power supply 12V - reading is 170V
- power supply 20V - reading is 275V
It seems that the error is almost linear, like actual reading is multiplied by a constant value (~14).
Is there anything that could be done here? Any suggestions are very appreciated!
/aleks
P.S. I replaced the batteries with a fresh set.
/aleks
