Multi Post Continuity Tester- Help Me Please! Urgent! :o)
galexanderr
Joined Aug 6, 2015
4
Thank you in advance!
I have been working on a multi post continuity tester for checking miswires of electric motors on our compressors. I milled a box from nylon and used 3 separate coin cell battery holders, LEDs, and ran Neg to one side Pos to the other, and it worked great. Until i realized that even when 2 wires were switch on the motor, it still would light up.
The Big question:
How do i separate the circuits on the tester so that when 2 post on the motor are switched (wired wrong) the tester will not light up? Do i need to use resistors somewhere? I know enough about electricity to be dangerous, but circuits etc. is over me. Here is some simples of what i got. The tester sits on top the terminal plate. I understand why they still light up, but don't know how to separate the 2 loops so they dont complete each other.
CORRECT TERMINAL WIRING---------------------INCORRECT WIRING -------------------------TESTER
upload_2015-8-6_14-3-33.png upload_2015-8-6_14-5-22.png upload_2015-8-6_14-29-14.png
30,810
Do the dashed lines indicate the possible internal winding connections or external miss wiring?
If internal, there should be no continuity on the top & middle pair in the centre pic.
Do you have an Ohm meter to actually measure any resistance?
galexanderr
Joined Aug 6, 2015
4
Yes the dashed lines are the jumpers below the Terminal Plate (in retro). When i check the Tester, it's fine. When i check the Terminal Plate, it's fine. I've checked for grounding issue and everything...i'm lost lol Heres a little drawing to show technically whats going on while the tester is on the terminal. Dashed (crossed) lines are the terminal jumpers and solids are the tester wiring.
