Multi Colour LED
MaxHeadRoom
Joined Jul 18, 2013
28,510
I am trying to find info on what is required to drive any of the 2 pin multi-colour LEDs, I have found a few LED sources, Digikey etc, but the Data sheets are always in Chinese, and even then, very vague!
Anyone had any experience?
MaxHeadRoom
Joined Jul 18, 2013
28,510
Yes, I cannot seem to find the requirement for the change?
Typically used in yard decorative fixtures.
I have a circuit for the YX8018, but need just the lamp requirement info.
Ya’akov
Joined Jan 27, 2019
8,973
The change is done internally on a cycle and restarts when the power is removed and reapplied.
They generally use 3.0-3.4V for 20mA
BobaMosfet
Joined Jul 1, 2009
2,105
what part number for your LED. A bipolar (2-pin) LED means you change polarity to change color. Usually they are Red/Green. If you change polarity back and forth fast enough, you may be able to fake orange/amber.
Here is a schematic example of one such bipolar LED that I did that with for a client project. Used 2 pins on an MCU so I could swap polarity however I wanted:
Ran it approximately 2V @ 8mA, either direction.
MaxHeadRoom
Joined Jul 18, 2013
28,510
These are RGB from Digikey COM-11450, but the model No is not critical, just need the requirement to change colour? cannot really decifer the info sheet.
I don't have the No. of the existing ones now in place.
MaxHeadRoom
Joined Jul 18, 2013
28,510
I tried and the one I tested just glowed steady Yellow/red , I want to recreate the existing YX8018 driven version, it alternates three colours every 0.5 sec or so.
djsfantasi
Joined Apr 11, 2010
9,151
Have you searched for this component on the Sparkfun site? There are several questions and answers on the site. Plus an English datasheet. The ds contains a timing diagram that shows the color sequence.
Audioguru again
Joined Oct 21, 2019
6,608
I have many solar garden lights that use a QX5252F IC, not the YX8018 that you have. Yours causes the solar panel to discharge the battery at night because it is missing a Schottky diode as I show. I also show the Schottky diode and filter capacitor that must be used for the colors-changing LED.
MaxHeadRoom
Joined Jul 18, 2013
28,510
Actually the one that is working uses the XC5252 as per my print in #10.
I am trying to get the LED to flash without the IC if possible.
According to the Youtube video it is a series of pulses.
Just need the frequency?
