Mr, I would like to use a 555 timer to alternate two blinking LED's,
wayneh
Joined Sep 9, 2010
18,168
I haven't played with a 555 lately but couldn't the Discharge pin be used to provide the invert of the Output pin, allowing elimination of Q1?
stspringer
Joined Oct 1, 2019
81
Another refinement eliminating two components and changing Q1 to a 2N3904.
Hello sghioto,
I followed your schematic, I think I got it right, and the low beams come on at full 12v, but when I remove the low beam wires and plug in the high beam wires, the LED's blink on and off, but they do NOT alternate, they both blink at the same time and the voltage never gets to 12v it's like 3 to 6 v.
Here are YouTube links so you can see what's happening
Thank you for your help. Almost there.
https://youtube.com/shorts/nBYageLGbTQ?feature=share
I didn't see your attachment till just now using a different transistor
sghioto
Joined Dec 31, 2017
8,751
No. Works just like it should.
Both circuits I posted worked fine using either the 2N3906 or the 2N3904.
I prefer the last refinement using the 2N3904.
stspringer
Joined Oct 1, 2019
81
What do you see different between the two transistors 2N3906 or the 2N3904 ? I will try again. Thanks
sghioto, I am unclear on some of the connections on your latest schematic, I am not well versed in schematics, can you give me some layman explanation to my confusion? thanks555_with_2N3904_timer_tester_schematic_edit_21.png
sghioto
Joined Dec 31, 2017
8,751
The transistors are the opposite of each other like the difference between a P and N channel mosfet.
Give me the link to the LED modules and the switch and I'll redraw the circuit and the wiring.
