MPS(Digital DCDC converter)
somaye2022
Joined Mar 23, 2022
100
So, you can use digital converter MP8854 (DATASHEET), 2.85V - 18V, 4A, High-Efficiency, Wide-Input, Synchronous, Step-Down Converter with Integrated Telemetry via I2C Interface.
It has efficiency about 95% at 2A output current.
It can work without using I2C interface if you do not need dynamically change of output voltage value.
Thank you. Yes, I already see that.
But I need dynamically change of output voltage value, because this is for the input of the FPGA.
So, what do you mean about 12C?
Danko
Joined Nov 22, 2017
2,241
I2C - it is interface between your microprocessor and digital converter.
Digital converter will change its output voltage by commands from microprocessor.
ADDED:
I2C Communication Protocol
I would like to know for example the difference between MP8854 and LTM4623, the Input from power Step down converster ist 5 V, and the Output is 1.2V with 2A output current requirment.
LTM4623 - 1.2V sets by feedback resistor, efficiency 87%, Multiphase Operation - yes, External Frequency Synchronization - yes, can not be digitally controlled.
MP8854 - 1.2V sets by feedback resistors, efficiency 95%, Multiphase Operation - no, External Frequency Synchronization - no, can be digitally controlled.
somaye2022
Joined Mar 23, 2022
100
Please elaborate. I don’t know what an MPS converter is. What are you converting? Signals? Or power?
Thank you for your reply,
There is a fpga board for camera.
And I thought that I could be make conceptional general questions.
I didn't know that it isn't a good way to ask a general question.
KeithWalker
Joined Jul 10, 2017
3,623
It is quite acceptable to ask a general question and so you got a general answer to it. The rest of the posts here are the result of misinterpretation of your wording. Most hi-tech guys are very analytical (including me) and so some of them do a lot of nit-picking before they come up with an answer, which is not necessarily a bad thing!
