motor MAX POWER
YOAVRAMAN2
Joined Apr 20, 2018
6
hi i have an dc 230v motor (D712-3532-01CH is the name or HS06023B CLASS H)
it dosent tell me what is the amper needed, those it meter ? and if it those what do you Suggest?
i am looking to make the engine powerfall as possible with batteries or Solar Cells, any ideas or Suggestions?
also if you can teach me how to check how much voltage is the output of my source it will be helping me.
yoav,
28,595
I did not look up the motor by type number because one also needs to have the manufacturers name in order to find much information. And the amount of current a motor of any kind certainly does matter a great deal. On the same tag that has the model number and the voltage should also be stated the horsepower , the RPM, and the rated current. DC motors come in a huge number of sizes, from very small to those that are very large and weigh several tons.. So you need to provide a lot more information before anybody can provide any useful answers.
YOAVRAMAN2
Joined Apr 20, 2018
6
i foun som info :
1. Our main products: Motor, 230V DC motor for blender and mixer,cheap motor,brush dc motor, 230V DC motor for blender and mixer, 230V DC motor for blender and mixer, 230V DC motor for blender and mixer, blender motor,Spur Gear motor, Micro Motor,Vibration motor etc
Approved CE/ROHS/CCC/VDE certificates
2.1.0V-120V~,60Hz .
3.Dimension : 25MM
4.On load performance :
Input current :1.5A
Input power:98W
speed :2000r/min
Torque:200g.cm
but now i am comfuzed it say that the motor is 230v but the input is 98W, also it says that it need 1.5A. if i input any more power what shood i ecspect (more current and voltege)? and when it wood start smoking?
28,595
The part of this description that confuses me is that it does not mention 230 volts at all. It only lists 1 volt to 120 volts at 60Hz. But it does describe the motor as being a brush type of motor. So it appears that it may run on a lot less than 230 volts. In fact, it will probably run on 12 volts DC, so if you want to make it run to verify that it does run, you can connect it across the 12 volt battery in a car and observe that it runs.
The description also implies that the circuit board that it was connected to reduced the supplied voltage from the 230 volt mains to some much lower value, because the (2) 2.1.0V-120V~,60Hz . You did not mention the brand of motor so I can still not locate any information. What sort of device is it removed from? Are you able to tell us that?
It is also entirely possible that the list that you have does not relate to this model of motor at all. Is the motor really 25mm diameter?
