Motor driver control
thuvk
Joined Mar 11, 2024
5
Hello, I'm currently looking for a motor driver to control a motor powered by a 10.95 volt 23Wh battery. I need a motor driver that can connect to the arduino for forward and backward movement. What is the best motor driver I can use for this motor. I have tried the l298N driver and it's not able to handle the power. It is also a dual motor and I just need to control the one motor.
LowQCab
Joined Nov 6, 2012
4,199
What are all of the Specifications of your Motor ?
What type of Mechanical-Load is on the Motor ?
Is Your Motor driving a Gear-Box of some sort ?
Have You measured the Motor's Peak-Current under Full-Load and/or Start-Up-Conditions ?
LowQCab
Joined Nov 6, 2012
4,199
What is your intended use of the Motor ?
~5 to ~10 pounds doesn't say very much about how the Motor will be Loaded under realistic-conditions.
Will You be using the Battery that came with the Scooter ?, or some other Battery ?
Your Motor could easily pull ~30-Amps from the Battery on start-up.
thuvk
Joined Mar 11, 2024
5
I would like to use the same battery yes. My project involves a cart that weigh about 10 pounds that will glide from one end to the other powered by this motor. The cart already has wheels. I would like the motor to move from a button push and when it reaches the other end the second button push would direct it the other way.
LowQCab
Joined Nov 6, 2012
4,199
This can easily be done with 2 Relays and 2 Limit-Switches.
Adding a Micro-Controller complicates things immensely.
If You need to control the acceleration and/or speed of the device,
a Voltage/Current-Limiting-Circuit could be added to the Relays and Limit-Switches.
"" How were you able to tell that this motor can pull 30 amps? ""
Fat-Wires, plus the fact that it is designed to move a ~200-pound person.
This is not a trivial-task Electrically.
That's why the original Controller burned-up.
The Components required to control that level of Power are generally not cheap,
but the manufacturer wants to build the device as cheaply as possible to make more profit.
