Seeking Recommendations for PCB Design and IC Driver for 3-Phase BLDC Motor Control with Hall Sensors
unohori
Joined Sep 4, 2023
I am new to the field of PCB design, and any suggestions from you would be greatly appreciated.
I need to design a PCB that can control a 3-Phase BLDC motor with hall sensors. I require an IC driver that includes integrated drivers. I have searched extensively, but I haven't found one that supports Hall sensors. Do you have any recommendations for a suitable IC driver? The BLDC specifications are 24V with a rated current of 1.3A.
Thank you for your time. Below is the link to the DC motor: https://www.zddriver.com/product/br...or/zpn-32-brushless-planetary-gear-motor.html
LowQCab
Joined Nov 6, 2012
5,102
You are not likely to get the advertised performance from that Motor unless You
also purchase one of the 3 Controllers offered by that same manufacturer,
specifically designed for that particular Gear-Motor.
High-End manufacturers quite often design their Motors and Controllers to be a matched set,
which may, or may not, be compatible with other similar generic devices.
unohori
Joined Sep 4, 2023
Hi, thanks for the reply.
Yes, you are right. But they didn't provide me with a schematic to use on the PCB. I need the BLDC driver to be on a PCB with all the other components.
unohori
Joined Sep 4, 2023
Designing and building your own PCB may be quite a challenge for a newcomer. In the UK I’ve used an Infineon driver board which attaches to an Arduino which might work for you?
https://uk.farnell.com/infineon/bldcshieldtle9879tobo1/shield-bldc-motor-driver/dp/3051942
Yes, I believe that I will work well on the project. I also found another one that is similar to this. I was analyzing one from Trinamic that offers it, interfacing with a microcontroller via SPI.
Thank you again.
Attached is the TMC6200BOB:https://www.trinamic.com/support/eval-kits/details/tmc6200-bob/
unohori
Joined Sep 4, 2023
Have you looked at the Motorola MC33035 & MC33039 etc?
Specifically aimed for this application?
That's a good choice, but I need to figure out how to control the Forward/Reverse function since it requires the use of an analog joystick, with Forward/Reverse depending on the position of the joystick
