Tronster
THANKS for the sketch this makes much clearer sence too me how the Acme rod nut and motor work together, I couldn't picture this without seeing a 2D image and you made a 3d image nice and thats how my box is build ,the image help.
But Will this work for me? It all depends on if it could be attached to the inside, because the box has to sit in anther box called a drainage well so theres no why it could be attached to the ouside.
Also when the motor moves the rod through the nut up and down as the lid moves the motor MUST move with the angle of motion too if the motor dose not move as the angle of the lid gos up/down the lid will jam up and not move correctly because the lid must open and close from 0-90 degrees. And the nut must be attach too the lid. The way the set up is in the image it will move as high the angle is' after the angle changes the motor must move with the changing of the lids position if it dosen't like i said the lid will jam up and if the motor is real strong and dose not detect a jam-up the motor will keep moving and may break the lid or just stop and start making noise because its iding because of the angle changed.
His there a way I could use something like this in side the box but still the motor at the bottom will still have to change it position when the lid gos pass a 45dg angle.it will have change with the lids position to work.
Do you have any other ideas how this could work.
and the nut must be connect to the lid.
