Steve
The way the lid is hinged its like a toy chest but there are no sides to attach mechanical means to the outside of the box like gas springs.
I did test with the spings when the box was not in well and it did eliminate alot of the lifting weight but the box must sit in well for drianage so you can't attach anything to the outside of the box.
I was thinking of using gas springs on the inside of the box but i have not found any that i could attach to the inside of the box, this would minimize alot of the force where i could use much less torque but I think i still will need at lease 340 to 390in lbs of torque or maybe less.So i know a mechanical leveage would help alot. and i can't use pullies and cables theres nothing to attach the cables to.
My lid dimensions are 4 feet x 3 feet 12sqft or 1728sq inches, 2pcs of 1/2 inch plywood glued together.
