Motor controller made by Design Concepts of Missouri?
zeljkostoj
Joined May 23, 2015
1
Hi All, I think I know the mating motor controller that drives this in a treadmill, and you can then simply drive the control board with a ttl-level drive control PWM and slow things to a crawl ;o) Message me for details, but if you have the original controller, verify it was made by Design Concepts of Missouri, Inc, and there will be a sticker on the frame of the controller which says ASM-xxxxx-xx. If you do not have the controller I may have one ;o)
Hi, Do you have motor controller made by Design Concepts of Missouri, Inc. ASM-ACD1U-4C 715-3617?
Edit:
This thread was split from Speed controller for ac motor.
Please don't hijack other member's thread, now you have your own thread.
Scott Wang.
ScottWang
Joined Aug 23, 2012
7,505
This makes post #2 & #3 redundant as they refer to the original Thread?
So you want to continuing the discussion after 6 months later?
If no one to reply that thread, will you reply it again?
If you think you want to continuing that discussion then I will move the posts of your and tcmtech back to that thread and reopen it.
30,776
I would have though that the two reply's to the original thread could have remained, if necessary, and the new post started a new thread.
Just that anyone reading this thread it would not make any sense.
ScottWang
Joined Aug 23, 2012
7,505
Ok, I moved them back, now, do you want to reopen it?
