HI,
I am working on a project which utilizes a 12v dc geared motor, connected to a acme screw, moving an object up and down.(Travel is only 4 inches).Object load will be 1 Kg Max.
The input will be 12v battery.
The Driver for the motor has a input for reversing the direction(requires a high on the input to do so)
http://www.robokits.co.in/documentation/DC_Motor_Driver_24V_20A.pdf
I will be installing two Limit Switches (one at the top and one at the bottom) to limit the travel.
The object after starting from the bottom will travel to the top and needs to stay there. (motor supply cut off)
The object after starting from the top will travel to the bottom and needs to stay there. (motor supply cut off)
The initial command for the motor to run will through a on- off switch(later through a pc, not sure)
could you guys please assist me with a circuit to do this.
superna
superna
