Simulating Protection circuit for Odrive pro motor controller and 14s Lipo batteries
mike__MecE
Joined Feb 20, 2022
92
The below question went unanswered so I am trying to figure it out with simulation.
https://forum.allaboutcircuits.com/...rectional-circuit-breaker-application.205326/
This circuit should give an overvoltage threshold of 58.4V and undervoltage threshold of 43.2V, but it doesn't seem to be following the theoretical thresholds. Does anyone see what could be wrong with the design?
The sim and LTC4368 datasheet and calculated values for R1-3 are below.
ParameterValueUnits
V_OSUV_Target0.003000000V
I_UV_Target0.000000010A
UV_TH_Target42.000000000V
OV_TH_Target58.000000000V
R1+R2_Target300,000.000000000Ohms
R3_Target24,900,000.000000000Ohms
R3_Selected25,600,000.000000000Ohms
R1_Target223,275.862068966Ohms
R1_Selected218,000.000000000Ohms
R2_Target82,000.000000000Ohms
R2_Selected82,000.000000000Ohms
UV_TH_Actual43.166666667V
OV_TH_Actual59.403669725V
mike__MecE
Joined Feb 20, 2022
92
Replying to myself lol, but just in case anyone is curious or reviewing this in the future, I discovered LTspice doesnt allow the capital M for megaohms, and then converting to kiloOhms I entered the wrong value. 25.6MOhms is 25600kOhms. Now the simulation is working nicely and doesnt seem to care much about R4 (results are roughly the same from R4 50k to 800k).
I'm still insterested in how to determine R4 if anyone knows, but for now I think the solution is accepttable and Im going to order a PCB to test it.
38,801
LTspice uses meg for the 1 million prefix.
It doesn't differentiate between capitals and small letters, so M is interpreted as m (milli)
It's arbitrary.
You can pick a convenient value for R4 and then calculate the rest of the resistor values for the voltages you want.
