Hi, I'm Tom and I'm very new to this kind of thing. Please forgive me if I've posted in the wrong section or even the wrong forum!
I have a board from a carousel storage system that has issues. I know the problem lies within this board as I have swapped the board with another carousel.
The symptoms;
Speed erratic
Runs when it is not supposed to
I was advised to change the two relays, which I've done. I have also changed the 2 large capacitors and the 2 chips.
There are some heat marks on the rear of the board near green resistor. There are no values on it but when tested it 18ohm.
I have removed the capacitors and tested and replaced the largest two as one was reading low.
Any advice will be very much appreciated
Tom
The symptoms;
Speed erratic
Tom
