Motor carbon brush sparking. Why it happens and how can I fix it?
Audioguru again
Joined Oct 21, 2019
6,826
When I was about 18 years old in my first rental apartment I made a fan from an old brushed motor and a propeller. Then I was visited by the RF cops because the sparks from my fan motor were causing radio and TV interference to many people. Some neighbors bought me a new non-sparking and safe fan.
Many motors today are brushless.
rambomhtri
Joined Nov 9, 2015
606
What?
I don't really get how the sparks of a motor is going to cause any RF trouble, let alone SO BIG to get a visit from the police. How did it happen?
28,651
The explanation of how interference from one device can interfere with others is simple: That RFI generating device is connected to the power system, and current flows both ways in a wired system. So the whole system becomes both a wired carrier and also a vast antenna, radiating whatever is present over a wide area. That is the reason that we now have standards for both radiated and conducted emissions from electrical devices.
zinda
Joined Mar 18, 2023
I came here because I have run across a very unusual problem. Retired maintenance mechanic who has fixed just about everything you can imagine. Now I just dabble in fixing vacuums and reselling them in my spare time.
There are some vacuum cleaner motors that seem to run forever, 40 years old and never touched, still producing mega suction and horsepower to spind the brushroller so fast the bearings will melt.
Recently vacuums have all gone through a change to bagless (I still use my old bagged Kenmore I bought new in 1985) and there are a few brands that have proven to be quite well made, or I should say we're quite well made. Like everything now, companies make a good product then chip away at it until they have a piece of junk for sale.
This has been the case with Shark and Dyson vacuums, both were at the top of their game 10 years ago with motors that last forever and plastics that were resilient and strong. Now it's just the opposite, the plastics have become brittle and weak. Motors tend to develop problems due to wear at the commuters.
I have a fairly new shark motor (I have boxes full of shark motors from the older models but they are larger} that's a mid size, not as small as their compact motors and much smaller than their full size. So I had no choice but to try and save it.
It wouldn't even run, even helping it didn't work. I checked the brushes and they were worn badly. Black dust around the inside of the motor compartment helped identify the problem. Since I have a box full of brand new brushes, I replaced them. Mine were drop in replacements but didn't have the back plate that holds them like the stock ones do. I know that's not a problem as long as the new back cap makes good contact with the stock cap. The springs are nice and long so there's no loss of contact even it the brushes wear.
I cleaned up the commuters plates to see if there was any excessive wear and found there was still some grooves between plates. I used done 600 grit sand paper cut ina thin strip and fed it passed the new brush and held it with my fingers while I used a drill motor to spin it. Everything looked great. I turned the paper around and wiggled the motor shaft back and forth to get the brushes seated on the curve better.
Tested it out and saw "excessive sparks" coming from 1 brush but not the other? I figured it was a simple pressure problem and checked the spring placement retested. Still there! I put a new brush in that side and quickly tested it again. Not as bad, but the original sparking was the type that sendsa glow onto the floor underneath it with a few sparks going ¼ turn or less with a free spark shooting out every so often
Checked everything again, ran the sandpaper with the grit facing the brush to seat it better. Tested better but as I let it run for a few minutes it looked like it was getting brighter. Just the opposite as expected.
Put another new brush in it and ran it for a while with the same results. I suspect that one brush is slightly out of position. Could be the holder is deformed slightly allowing it to slip enough that it's touching a plate that it shouldn't be able to. I'm going to squeeze the holder a bit tighter on one side to offset it so the brush wear matches the other side.
From what I've seen brushes are rarely positioned so they wear in the center of the brush, typically one side will be worn shorter, suggesting that it's not on center but more advanced so the incoming bars will be worn deeper than the trailing edges. Since I'm seeing this happening on one side I'm convinced that when brushes wear downtoa point where they are not fully supported by the holder piece, they can put pressure on the holder as they spin causing the frame to distort at the end. This will allow the brush to shift slightly more than it should. The problem is mine is showing a dead center wear groove?
Since vacuum motors olygooe direction, it's less likely for a loose brush to create a deformed holder in both sides as a drill motor could do from forward and reverse movement. Since the brush holders stick out quite far, the motor compartment even has notches on both sides for the brushes to fit into the space. The motor uses a rubber mount on the bottom to keep it centered but the gap is tight around the brush notches and possibly may have taken a hard fall that hit the brush holder in the notch.
If anyone else can think of any way 1 brush could be sparking excessively while the other rubs perfectly, please post your theory!
I'm going to go take a look and see if I can move the holder at all. It felt like the holder wasn't as tightly formed as most others are. The brush easily slid in place. Many times I need to do a tiny bit of surface removal to get them to slide freely but without any slop.
Ty, there's a lot of good info posted here, I think this covers most problems people might see but not mine, I had to get it posted in case others have run into this strange case.
zinda
Joined Mar 18, 2023
I forgot to add that the motor does seem to run fine, very fast and powerful, no strange noises or issues you'd normally get while brushes are arcing. It gets hot on the one side much quicker than the other. Not excessively hot but noticably when I pick it up after a few minutes I can tell which side is the arcing one by touch.
zinda
Joined Mar 18, 2023
I thought about that but usually there's a very noticable loss in power when that happens as well as the sound of the motor itself gives off a burrrrr sound. I ran it some more and I checked the holders to see how strong they are and it would be very difficult to move or distort them unless that area was really hot (which I would not doubt could happen) but there'd be more signs of burning around there and it was generally very clean. I appreciatethe intelligent and speedy answer. I'm going to keep it around and test it under normal conditions to see how long it will run. I'll replace the motor as soon as I find another and then sell it. I prefer using my 1985 Sears Kenmore bagged vacuum over any bagless, better cleaning ability and no maintenance. I don't understand what people are thinking paying $300 to $700 for a vacuum that will last 2 or 3 years and never clean as good as an old bagged vacuum that lasts 40 years using bags that cost less than $1 each and last 4 months!
Generally vacuum motors are very robust and run for many years without ever any problems. Typically the copper wears down well before the brushes do. I've repaired and sold close to or over 1000 vacuums over the years and so far I've only seen 2 bad motors that quit working due to normal wear. Other than those 2 I've only seen 3 that were damaged by missuse. Typically the culprit is a kid that drops a coin or button down inside the tube that leads to the motor. It's easily accessible once the dirt cup is removed and mom is emptying it. That tube will allow that object a straight path into the inlet eventually it will enter the impeller and at 20k rpms it will break the fins and cause a severe imbalance. Replacing the impeller isn't impossible but rarely are extact replacement parts available even when you stock up on motors like I have. There's a better chance that another motor will drop in and work even if it's made for another brand. Shark and Dyson have the strongest motors. Shark has the best since they can beat the Dyson easily but use a motor that's about ¼ to ⅓ smaller in overall size and draw less power.
This applies to both vacuums circa 2010 or so, both have opted to use far less robust motors in an effort to make more sales. It's sad how things are simply made to work for a brief period of time now. The main selling point used to be how reliable things were and people bought things that were made to last indefinitely. Expecting everything to work as good as new 20 years down the road was important. Now it's never considered, whatever has the newest gimmick is the big seller and every other company follows suit, all mimicking the big seller with their own version. Typically anything that is new is never better, most seem to be aimed at reducing life expectancy and you'll pay more for it. That's the new way of manufacturing!
I'm constantly amazed at how engineering purposely reduces material at critical points, failure is unavoidable when bearings become even a few degrees higher, replacing the entire case is the only fix. Could be avoidable with a 1 cent piece of thin aluminum or adding more support at critical high temp or high stress areas. I see holes designed at those areas like your see on a off road racing vehicle trying to lose weight but doing it at all the wrong places. Today, I was reassembling a vacuum and the first screw i put in, broke the receiving post off the inside of the case. Inspection showed such a small amount of material used at the connection, I was in disbelief. Normally I would drill the hole out and pilot hole into the material behind it, there was no material in this case. I had to use another case I had laying around. At least it broke on the 1st screw and not the last!
zinda
Joined Mar 18, 2023
I ran the vacuum today for an hour or so of normal use. It worked fine up till the end. I noticed it was not up to par with my 37 year old Kenmore and even normal use was giving it a beating. Stuff clogged easily it the hose where my Kenmore wouldn't have even slowed. I know much of it is design but I was using it without the post motor filter on top of it all. I want to be able to hear the motor and see if I saw fire or if it lit up the area from the arcing. I put my ear closer when I was done and it didn't sound really different but I could tell it was not firing perfectly. The air coming out was pretty hot but that's typical of vacuums. I took the motor out and inspected it again and everything looks fine but the difference in the original height of the copper was about ⅛" taller than where it is now (looking at the edge of the worn area compared to the ridge sticking out above and below the brush path). I'm starting to think that the diameter of the commutator shrinking may be allowing the brush to stay in contact with the previous one. I wired it up to bench test and now both sides are throwing sparks heavily. I'm going to file a relief angle to keep the brushes on less of the copper.
If this fixes it then this motor has simply been worn possibly from too much spring pressure and dirt build up sticking to the motor parts. The bearings are surprisingly still in great shape so that's strange. I'll report back if there's any huge change. This will only take a few minutes.
28,651
Unfortunately a Growler is a rather specialized piece of equipment that not many have, unless they are in the motor repair business. I am thinking about how to rig for a similar test without having a growler. Not sure as to how else to do that test.
Are you aware of another scheme to do that test, Max???
MaxHeadRoom
Joined Jul 18, 2013
30,890
Typically a resistance test is no sub for the Growler, the difference between a normal reading and a short is usually too insignificant to detect with Ohm test.
28,651
Certainly that is true. BUT if no growler is available it is an available analysis tool. AND it can also reveal a coil short circuit to the laminations, a sure sign of failure.
