I am trying to restore an audio record cleaning machine. One of the small motors drives a vacuum pump but needs a small "push" to get started. It is noted elsewhere on the net that this is a common problem with this unit and is why it is no longer made, nor are parts available. Unfortunately the motor is installed in a sealed part of the unit and it is a pain to keep pulling the unit apart to start it. This motor seldom runs longer than 3 minutes before being turned off. This is a simple 2 wire motor (and ground wire) that has no capacitors. I experimented with different values and ended by placing a 20 mfd cap in series in a wire going to the motor. Now it starts and runs fine. This is a 440V cap that says it is a "start and run" cap. Here is my question - can I simply leave this in the circuit or do I need to install a switch to remove it from the circuit once the motor starts?
Thanks
Thanks
