Motion / Direction / Magnetic Movements
LowQCab
Joined Nov 6, 2012
5,101
You can certainly make it mechanically rotate,
with no apparent change in Magnetic-Field behavior,
but You can't make it rotate by means of an outside Magnetic influence
unless it has been Magnetized in a different orientation other than strictly axial,
in which case, the Magnetic-Field wouldn't exactly follow your drawn-lines.
Maybe by means of Eddy-Current-influence ????,
but it would probably be a very inefficient arrangement.
Irving
Joined Jan 30, 2016
5,170
Not directly IMHO, as you would need two different magnetic axes.
If you had 2 toroids attached, it could work.
