mosfets resistors
Audioguru again
Joined Oct 21, 2019
6,826
The IRFP250 Mosfet is rated for 200V so use a 100 nanofarads (0.1uF) capacitor rated for 200V.
The resistors do not get hot so 1/4W ones are fine.
Audioguru again
Joined Oct 21, 2019
6,826
There is nothing in the small schematic that shows resistor values.
What voltage and what frequency drives the 1k resistor?
What is the inductance of the load?
sghioto
Joined Dec 31, 2017
8,634
All the resistor values are shown.
The TS wants to know why the components are arranged in that way.
The 10K resistor in the left schematic ensures the FET is off when no signal is present. The 1K resistor is only needed if the gate to source junction ever shorted thus shorting whatever is driving the FET. Other times a resistive divider at the gate might be used if the driving signal is greater than the max voltage allowed at the gate.
The 10K and 100nf cap in the right schematic form what is called a "snubber" this is to protect the mosfet when switching inductive loads. No idea if the values shown are valid, it would depend on the actual circuit.
