MOSFETs, I don't understand something about them
lukamila82
Joined Jun 4, 2018
So today I woke up in the morning and got the idea to make a bicycle phone charger and I wanted to use a MOSFET and an LM7805 voltage regulator.
The generator I have would be turned on by the wheel and it would generate a voltage between 1 and 7 volts. If the voltage is over 5 volts it would get regulated by the LM7805 but if it is under 5V, it can't be regulated because the LM7805 can't step up voltages so I thought that I might use a logic level MOSFET as a switch. Basically, if the voltage is under 5V, the MOSFET won't allow it to go trough, but if it is above 5V, it could go trough.
I can't seem to understand how to wire up a MOSFET to do that, but I have tried something (the picture below).
Please help me and sorry if I make noob mistakes, I'm fourteen and I am just learning basics of electronics for now.
ericgibbs
Joined Jan 29, 2010
21,567
hi 82,
Welcome to AAC.
When using a 7805 5v regulator, the input voltage must be at least 2.5V higher than 5v, so it would require a 7.5v input.
There are Low voltage drop out regulators which require only ~0.1V ie: 5v input.
E
38,770
Use a low-dropout regulator such as this.
It has a minimum voltage drop of 500mV.
If the input voltage is 5.5V or above it will regulate the output voltage to 5V.
Below 5.5V the output will be about 500mv below the input.
