thatoneguy
- Joined Feb 19, 2009
- 6,359
I don't think the X-Y function is what you are looking for. That setting will give pretty lissajous figures if both channels are fed with AC, adn other useful info though.Yes, I missed to draw it. The +80V is from transform type power supply, it's earth doesn't connect ground, only the case of power supply does.
Ah, I know the (X-Y) function on scope, thank.
By the way, the circuit can't function (even VS connect to th source of mosfet). Could anyone help to advise what's wrong?
Thanks,
Look for a button/menu choice labeled "Invert" for channel B and enable it
Next look for a button/menu choice labeled "Add", and enable it.
You should have A+-B, or A-B as a single trace on the screen.
