Mosfet Turn-on Transient Question(s)
Status
Not open for further replies.
BearSub
Joined Jan 11, 2018
Referring to the graph below, why is it that when a Mosfet turns on, Vds does not decrease until the channel is supporting the full-load current? From my understanding, Vds should start decaying as soon as Vgs equals Vth of the Mosfet but that is not the case.
From the research that I have done, I found that this is at least partly due to the behavior of a diode (I am assuming that the diode being referred to here is the freewheeling diode of an clamped inductive load?), but that does not seem clear me at all.
Mainly, I am just trying to get a better understanding of how Mosfets works, particularly in relation to power supply design.
Edit: Forgot to add the graph.
ScottWang
Joined Aug 23, 2012
7,509
Which thread you are referring to?
(Your answer maybe useful for other members, after you answer the question and then this thread will be closed)
Status
