Mosfet recomendation
Rscott9399
Joined Jan 13, 2017
51
Hey guys
Im looking for a part recommendation
I need a n channel that can do 1A + with a mohm RDS on.
Must be able to take 40V from source to drain
Anyone have any ideas. Essentially i need a super low voltage drop across the source to drain
BobaMosfet
Joined Jul 1, 2009
2,211
digikey has a fantastic parametric search option where you can specify such things and they will show you all they have- you can then get the datasheet and ensure it meets your need.
Papabravo
Joined Feb 24, 2006
22,082
There is another aspect of the problem to consider. I assume you want such a part to be readily available at a reasonable cost. Besides the technical specs, what would be a "reasonable" cost?
Papabravo
Joined Feb 24, 2006
22,082
Rscott9399
Joined Jan 13, 2017
51
should of added that, looking for a 5v gate or i will level shift if needed
package i dont care either way but smaller the better
