Mosfet pwm
Status
Not open for further replies.
b1u3sf4n09
Joined May 23, 2014
113
Also, did you size the mosfet for the inrush current or the running current? Motors pull a high initial current when they are building their magnetic field on startup. I've seen it burn up solid state relays, so it's something to keep in mind.
bertus
Joined Apr 5, 2008
22,928
I have merged the threads.
You can give a reply to a thread using the
button on the end of the thread.
Please UPLOAD attachments to the forum.
In your first post there is a link to your local PC.
Here is HOW to UPLOAD attachment to the forum:
Attachments and Images
domingojordan
Joined Aug 11, 2014
17
I need some help to figure out why i keep frying a mosfet. belove you will find a striped out motor control circuitry that i want to use to control the speed of a brushed motor. the motor rating is as follow: Brushed motor rated 120vac 12amps 1400w 50/60hz. The circuit start working at a low pwm pulse( analogWrite(pinNum, 20) ). I works slow but it is a litle noicy. When i increase the pwm pulse it snaps the mosfet and the motor start working at full speed and it gets wery hot in a short time. I had run the motor with a full motor controller circuitry that has it is own controller chip and the motor runs fine. I can pwm that circuitry with my controller at any pwm pulse. I want to pwm the mosfet gate and be able to control the speed of my motor. below are both circuitris the full motor control and the striped out version. I believe that some how i need to limit the current that the motor is getting because when i use the full circuitry the motor does not get hot and it runs smooth and i can controll the speed. I am not very electronic involved person but I am a quick learner.
bertus
Joined Apr 5, 2008
22,928
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics.
The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
Status
