Why is high side called high side when load is between ground and the fet. Seems ground would be the low side. Same with low side, load connected to supply and fet, seems that would be called high. What makes one high and one low. Just seems the naming is backwards. Thanks
Below is the picture of high side and low side, what is correct...? This picture came from Electrical Engineering website.
What is correct....?
