praondevou
- Joined Jul 9, 2011
- 2,942
If it's a DCDC converter then it has a capacitor at the output. Normally the converter deosn't have a control over the discharge of this capacitor, so yes, it will limit it's regulation to 1A but the output capacitor could very well provide much more than this.Another thing is that our supply to the MOSFET is only limited to 1A current. We are using the PB150S DC-DC Converter as a supply to our MOSFET and this component has a maximum output current of only 1A so even if the current limiter is not working the supply will still limit the current to 1A only.
Look, do us a favor and provide at least this data:
1. Waveform on the 1R current limiter resistor.
2. value of the capacitor connected to the MOSFET.
There are thousands of working MOSFET switching circuits on the internet, so there is absolutely nothing confidential about it. You could make a hand-drawing of the
1. MOSFET, capacitor, resistor combination
2. Gate drive and gate resistor
EDIT: I just had a look to see if there is a "better" MOSFET outthere, as you requested. I can't find any. Wow, you found the most powerful p-channel MOSFET and you destroyed several of them. Don't you think it's time to revise your circuit? ;-)
Is this a prototype or is this going into production?
