mc33152 Datasheet mentions this, I bolded it.
https://www.onsemi.com/pub/Collateral/MC34152-D.PDF
'No over current or thermal protection has been designed into the device, so output shorting to VCC or ground must be avoided. Parasitic inductance in series with the load will cause the driver outputs to ring above VCC during the turn−on transition, and below ground during the turn−off transition. With CMOS drivers, this mode of operation can cause a destructive output latchup condition. The MC34152 is immune to output latchup. The Drive Outputs contain an internal diode to VCC for clamping positive voltage transients.'
The 12vdc to 120vac inverter came with RX3152, which seems to be the same function, but I was wondering if this MC33152 is better?
My problem with this inverter is everytime the output is overloaded, instead of safely shutting down, it self destructs as in burns up all the input mosfets, gate resistors, and mosfet drivers. So If I rebuild it again, this will be the 3rd time. So this time instead of using RX3152, (can find on Ebay only), am going with mc33152. Will that stop the destruction, or it is something else ?
What causes the mosfet destruction, they don't turn off under overload? Power mosfets are IRF3205. I have a set of them so I might as well use them and fix it again.
I dont suppose any breaker in the AC output could work fast enough to keep it from burning up input mosfets?
