Hi guys. I'm trying to use a mosfet with PWM for peltier control.
In any case, intially I just want a circuit that conduct at 5V and does not conduct at 0V. I'm currently failing with this.
You can see my circuit below. What's weird is that there is always a voltage drop from 9V to 0V across the top resistor no matter what the voltage at the gate is. I would assume that if the mosfet was closed this wouldn't be the case.
I'm using this:
http://uk.rs-online.com/web/search/...searchProducts&searchTerm=708-4796+&x=38&y=14
And a 9V battery source.
I've also tried without the resistor. I just thought it might remove any potential charge that could build up.
Any insight would be appreciated.
I'm using this:
