MOSFET CS Amplifier (VTC)
jegues
Joined Sep 13, 2010
733
See figure attached for the question and the figures given.
I'm having a little trouble for part a), I know at point A,
\(v_{GS} = V_{t}\) and the transistor is just turning on, and since \(v_{DS} > 0 \) we will enter saturation.
For point B,
\(v_{GS} - V_{t} = v_{DS}\)
but how do I determine Rd from this? I haven't been told anything about vGS or iD.
Hopefully once I get the ball rolling on part a), parts b), c) & d) should fall into place.
Thanks again!
EDIT:
a) Vgs = Vds + Vt, Vds = 0.6V
\(i_{D} = \frac{1}{2}k_{n}(v_{GS} - V_{t})^{2}\)
\(i_{D} = \frac{V_{DD} - V_{DS}}{R_{D}}\)
\(i_{D} = 1.25mA, \quad R_{D} = 1.6k \Omega\)
b)
\(v_{DS} = 0.5V \quad \rightarrow \quad v_{GS} = 1V\)
\(v_{DS} = 2.5V \quad \rightarrow \quad v_{GS} = 3V\)
I'm stuck on part c) now.
Jony130
Joined Feb 17, 2009
5,601
In the first place tell me why you want to find Rd ??
Rd is given and its equal to Rd = 24kΩ
As for question a
The point A is equal to
\(V_{ds} = V_{t}\)
And point B
\(V_{ds} = V_{gs} - V_{t}\)
And we also know that:
\(V_{ds} = I_{d} * R_{d}\)
And
\(I_{D} = \frac{1}{2}K_{n}(V_{GS} - V_{T})^{2}\)
So you need to solve this equation
\(V_{dd} - (I_{d} * R_{d}) = V_{gs} - V_{t} = V_{dd} - \frac{1}{2}K_{n}(V_{GS} - V_{T})^{2}*Rd = (V_{gs} - V_{t})\)
jegues
Joined Sep 13, 2010
733
As for question a
\(V_{ds} = V_{t}\)
And point B
And
\(I_{d} * R_{d} = V_{gs} - V_{t} = \frac{1}{2}K_{n}(V_{GS} - V_{T})^{2}*Rd = (V_{gs} - V_{t})\)
Sorry I had posted the wrong question by mistake, the correct one is up there now.
Jony130
Joined Feb 17, 2009
5,601
I must have done that incorrectly.
How do I get the value of Vgs for Vds = 2.5V
Is part a) okay?
The part a) looks okay except the last part Vgs=3V for Vds = 2.5V.
To get 2.5V as a Vds the drain currant must be equal to zero.
Then there will be no voltage drop across Rd resistor and Vds = Vdd.
jegues
Joined Sep 13, 2010
733
So as a result, Vgs = Vt = 0.5V, correct?
jegues
Joined Sep 13, 2010
733
For part C),
I solved the 2 equations for id for Vds and found that Vds = 0.077V, id = 1.51mA and rd = 50.85 ohms.
Is this correct?
