mosfet circuit modify
LAOADAM
Joined Nov 21, 2018
956
The picture attached is an Arduino_Optocoupler_Mosfet control circuit, can I simply multiple Mosfets in parallel, say 4 of. Can the circuit 4 times large the current output?
Adam
AnalogKid
Joined Aug 1, 2013
12,129
Yes, BUT . . .
1. You would be better off and get more consistent performance if you use one large MOSFET rather than 4 small ones.
2. The circuit will place 24 V across the gate-source barrier. For most MOSFETs, this barrier is rated for a maximum of 20 V, and the FET is fully enhanced with less than 10 V. To fix this, add a resistor between the +24 V source and the optocoupler collector. If the two resistors are of equal value, such as 10 K, there will be just under 12 V on the gate; a nice, safe value.
ak
LowQCab
Joined Nov 6, 2012
5,101
It depends on how fast you need the MOSFETs to turn completely-On, and completely-Off.
The Gate of a FET is basically a Capacitor,
how fast can you charge, and dis-charge it.
LAOADAM
Joined Nov 21, 2018
956
Yes, BUT . . .
ak
Thanks.
LAOADAM
Joined Nov 21, 2018
956
You can parallel MOSFETs, but you better know what you are doing.
Thanks.
actually I may have a silly question here, I attached a picture of IRF3205, that documented a 110A current handle in certain condition.
The IRF32025's pin size: s=0.55*1.4 ~0.77mm square, can it handle that much current?
sagor
Joined Mar 10, 2019
1,049
Thanks.
No, if you notice the little "5" in a circle beside the 110A in the datasheet, you can see that the package is limited to 75A due to the design of the package, and that assumes all other parameters are below maximum limits (like heat dissipation good enough to keep temps low)
https://www.infineon.com/dgdl/irf3205pbf.pdf?fileId=5546d462533600a4015355def244190a
LAOADAM
Joined Nov 21, 2018
956
