Hello
I've searched around a bunch but cant find an example of this circuit...
Goal:
Switch a 3 wire ball valve (see circuit below) open and closed with an arduino utilizing two n type mosfets (AOD514/AOI514/AOY514 30V N-Channel AlphaMOS)
Problem:
Circuit requires common neg based on ball valve design, which "turns both lights on" in simulation below. I need to some how separate the common neg??
Note if I wire up the circuit below and don't join neg of bulbs I can turn the bulbs on individually ... which in theory would allow me to have isolated 12v to my ball valve open or close. I have the real life circuit in front of me and going hi with pin 8 or pin 7 puts 12v to both open and closed inputs of valve.
Any feedback would be appreciated - Thanks!
Circuit simulation is here:
https://www.tinkercad.com/things/im...=dAdYueOr-MirBfLbPEbIbh0CmiU5m4ERdL1KKTyyvxU=
Goal:
Problem:
