More on impedance and instant energy stored in capacitor
WBahn
Joined Mar 31, 2012
33,341
Oh, yeah
You're right. Thanks again.
I didn't find anything in "the book" related to what we were talking about
Could this subject go to the book?
If you are talking about the E-Book on AAC, then read the page on contributing to it at http://www.allaboutcircuits.com/l_contribute.html
What you are talking about isn't something, in my opinion, that warrants significant treatment in the text itself since it is (1) a straight-forward application of fundamental principles and (2) doesn't develop a particularly general result that is widely applicable to circuits in general. But that's my opinion. It is, however, completely reasonable as an example worked for people or as a problem for people to work on their own.
kiroma
Joined Apr 30, 2014
326
We just got off the subject, and I forgot to go back again and ask if someone knows how to know the rms voltage of the capacitor in an AC series circuit.
Thanks for your dedication.
WBahn
Joined Mar 31, 2012
33,341
Do you mean how to find it in general, or do you have a specific circuit example in mind?
Have you read the E-Book on AC analysis?
#12
Joined Nov 30, 2010
18,224
Ohm's Law
E=IR
E = I (Xc) give or take Xesr and Xesl depending on how accurate you want to be.
alfacliff
Joined Dec 13, 2013
2,458
have you included the inductance of the capacitor? different types of capacitors have different internal inductance, which will affect the instantaneous currents.
kiroma
Joined Apr 30, 2014
326
Ohm's Law
E=IR
Thanks. I tried it but didn't work with the simulations I made. I'll try again.
By the way, what you mean by Xesr and Xesl?
kiroma
Joined Apr 30, 2014
326
Ohm's Law
E=IR
Jony130
Joined Feb 17, 2009
5,601
By the way, what you mean byXesr and Xesl?
Are you sure you use a right equations? For sinusoidal steady state AV we have
\(Itot =\frac{Vin} {sqrt{R^2 + Xc^2}}\)
And
\(Vc = Itot * Xc\)
where
\(Xc = \frac{1}{2*\pi*F*C}\)
Or read this
http://www.allaboutcircuits.com/vol_2/chpt_4/3.html
Or try to watch this videos
http://ocw.mit.edu/courses/electric...s-and-electronics-spring-2007/video-lectures/
Lecture 16: Sinusoidal Steady State
Lecture 17: The Impedance Model
ESR is Equivalent Series Resistance
ESL is Equivalent Series Inductance
MrAl
Joined Jun 17, 2014
13,887
The best way to understand AC currents and AC voltages in AC circuits is to use complex impedances. This makes any circuit easier to analyze. For the resistor in series with a capacitor driven by an AC voltage source this is very simple. It's like Ohms Law except you use complex quantities instead of real quantities.
For a resistor R1 and R2 in series with a voltage source E where R1 is upper and R2 is lower resistor, we have the voltage across the lower resistor R2:
vR2=E*R2/(R1+R2)
For a resistor R1 and cap C1 with voltage source E where C1 is in the place of R2 above, we have:
vC1=E*zC1/(R1+zC1)
So here we use the impedance of C1 which we call zC1 above. This is equal to:
zC1=1/(j*w*C1)
where
w is the angular frequency equal to 2*pi*f where f is the frequency in Hertz, and
j is the imaginary operator.
So once we calculate the voltage across the cap we get:
vC1=E/(j*w*C1*R1+1)
Since this is a complex quantity we have amplitude:
|vC1|=E/sqrt(w^2*C1^2*R1^2+1)
and there is a phase shift between input AC and cap AC voltages:
Phase=atan2(imagpart,realpart)
where imagpart is the imaginary part of vC1 and realpart is the real part of vC1.
So we see that for an AC quantity like this we have two parts to consider: the amplitude and the phase shift.
Doing it this way allows us to cover a very very wide class of circuits including filters.
Also, when you say "instant energy" what you mean is "instantaneous energy" or maybe "instantaneous power". For a circuit with changing voltage v(t) and changing current i(t) the instantaneous power is:
p(t)=v(t)*i(t)
The average power is:
P=(1/T)*integral[0 to T](p(t)) dt
where T is the total period.
BR-549
Joined Sep 22, 2013
4,928
I don't understand why anyone would need to know instantaneous energy stored in a capacitor, other than a purely mathematical exercise.
And if you do, those equations will not tell you.
Those equations will only tell you the energy that is stored due to the capacitance of the capacitor.
Not the total energy stored in a capacitor.
That's why it is 1/2. The resistance has nothing to do with it. Resistance can not store.
The other half of the energy stored in a capacitor is in the magnetic field of the capacitor.
A capacitor and a inductor have the same function....that is to store a field.
A field ALWAYS has two EQUAL ENERGY parts......electric and magnetic.
You can change the E and M concentrations with area, but not the energy equality.
A capacitor is constructed to intensify the E field, an inductor intensifies the M.
Both devices still have equal un-intensified fields.
ALWAYS.
ALWAYS.
There is only one EM energy field that we 'see' expressed by it's electric and magnetic properties that vary with its interaction with matter. There's only one field there, but there's two different ways of seeing it from our observer point of reference.
38,938
Don't know where you got that from. :confused: There is no magnetic field in a charged static capacitor, only an electric field. There is no "other half of the energy stored in a capacitor".
A magnetic field is generated by moving charge.
There are not always "two EQUAL ENERGY parts" to a field. Fields can be purely electric or purely magnetic.
WBahn
Joined Mar 31, 2012
33,341
ALWAYS.
So, according to you, for every joule of energy that is drawn out of the battery we store a half a joule of energy in the electric field of a capacitor, half a joule of energy in the magnetic field of a capacitor, and half a joule of energy gets converted to thermal energy in the resistor.
Interesting.
MrAl
Joined Jun 17, 2014
13,887
ALWAYS.
Instantaneous power would be used to calculate average power, so it is a precursor to knowing the average power. We'd need to know that first before we could calculate the average power which of course has great physical significance. So the instantaneous value is used to calculate something more physical. He may be trying to get the total energy doing the calculation in a certain way.
kiroma
Joined Apr 30, 2014
326
I really don't know how to answer your question about why this is interesting
But I'd like to say that I like to know these kinds of things.
Yes, resistence has nothing to do with the capability of store energy.
But it won't matter integrating from 0 to infinity, because it'll give you CV^2/2
And will matter when there's another period of time because depends on the capacitance and on the resistance to charge the capacitor
So it'll determinate how much work has been stored in a certain period of time given the values to set the work stored.
It's clear for me, sorry if I couldn't express myself.
WBahn
Joined Mar 31, 2012
33,341
In general. I tried to find, but I didn't.
In general, you have to rely on understanding general concepts about how to work with different components and also understanding the general concepts of how to apply basic principles to the analysis of circuits in general.
When you say that you want to work from first principles, I'm not sure what you would consider "first principles". We could start with the force between two electric charges and then build up the concept of an electric field and electric potential energy and from that the concept of voltage and then develop the concept of a capacitor that stores charge according to the relationship
Q \; = \; CV
where Q is the charge stored on the capacitor plates (+Q on one and -Q ont he other), V is the voltage between the plates, and where the capacitance, C, is defined by this relationship (for linear capacitors). This is known as the constitutive equation for a linear capacitor.
In general, Q and V are functions of time while C (again, for linear capacitors) is a constant, so a more explicit expression is
q(t) \; = \; C \cdot v(t)
An electric current is the flow of charge which is also the time-rate-of-change of charge, so
i(t) \; = \; \frac{dq(t)}{dt}
Differentiating the constitutive equation for the capacitor we get
\frac{dq(t)}{dt} \; = \; \frac{d}{dt}\( C \cdot v(t) \)
i(t) \; = \; C \frac{dv(t)}{dt}
If we are dealing with sinusoidal (i.e., "AC") signals, then both the voltage and the current will be sinusoids. Without loss of generality, we can use the voltage as the reference (which just means that we adjust our clock so that the v(t) has zero phase angle) and we get:
v(t) \; = \; V_0 \sin\( \omega t\)
i(t) \; = \; \omega C V_0 \cos\( \omega t\)
i(t) \; = \; \omega C V_0 \sin\( \omega t + \frac{\pi}{2}\)
The next step requires an side. Using Euler's formula with complex exponentials, we can write
e^{j \Theta } \; = \; \cos \( \Theta \) \; + \; j \sin \( \Theta \)
where
j \; = \; \sqrt{-1}
which means that
\sin \( \Theta \) \; = \; Im \lbrace e^{j \Theta } \rbrace
We also know the following
e^{\(a+b\)} \; = \; \( e^a \) \( e^b \)
e^{+j\frac{\pi}{2}} \; = \; j
e^{-j\frac{\pi}{2}} \; = \; -j \; = \; \frac{1}{j}
With all of these, we can write
v(t) \; = \; Im \lbrace V_0 e^{j \omega t } \rbrace
i(t) \; = \; Im \lbrace j \omega C V_0 e^{j \omega t} \rbrace
Notice that the exponential term is common to both expressions and that it conveys no information other than the frequency that the system is operating at. It turns out that this will be a common factor in all of our expressions, so we can factor it out and work with everything that's left and then, at the end, multiply it back in. That leaves us with
v(t) \; = \; Im \lbrace \bar{V} e^{j \omega t } \rbrace
i(t) \; = \; Im \lbrace j \bar{I} e^{j \omega t} \rbrace
where
\bar{V} \; = \; V_o
\bar{I} \; = \; j \omega C \bar{V}
These are known as the "phasor" voltages and currents and, in general, they are complex quantities. They map very conveniently to the time domain v(t) and i(t) because the magnitude of the phasor is the magnitude of the sinusoid while the phase angle of the phasor is the phase angle of the sinusoid. Because this mapping is to simple and straight-forward, we don't have to actually go through the hoops of multiplying the phasor by the exponential term that we factored out and then taking the imaginary part, we can just write down the result by inspection.
Now it might seem that we made things a lot harder by introducing complex exponentials and phasors, but we have actually made life a lot simpler because, using an analogy to the resistance, R, in Ohm's Law, we can define an impedance, Z, to be
\bar{Z} \; = \; \frac{\bar{V}}{\bar{I}}
Thus, for a capacitor, the impedance is
\bar{Z_C} \; = \; \frac{1}{j \omega C}
We can pursue a similar treatment and find the impedance for a resistor and for an inductor are
\bar{Z_R} \; = \; R
\bar{Z_L} \; = \; j \omega L
At this point we have a very powerful tool to analyze linear AC circuits containing resistors, capacitors, and inductors. We use the frequency to determine the phasors for the voltage and current sources as well as the impedances for all of the components. We can then use all of the same techniques that we use for DC circuits involving just resistors (in addition to voltage and current sources) to solve for the phasor voltages and currents of interest. Finally, we can convert these phasors to time domain expressions for those voltages and currents.
I want to thank WBahn for his excellent post showing how complex math simplifies problems.
A video explanation of why Phasors are simpler and mentally intuitive once you get the phasor polar coordinate patterns.
