Hello, there is main breaker box which we are trying to connect with sub panels of 50 amp breakers which are further connected with power converters which help to power up the machines, I wanted to test the ac load on power converter point by using embedded controller called particle photon and some current sensor which is easy to connect with Internet and send the reading analysis to database which also send some push notification when the current or peak voltage will not be there in desired range which is mentioned for desired range of specification,
Since I am not good in this kind of solutions, I found out current sensors which can be monitor the current range at maximum 70 amps https://store.ncd.io/product/2-chan...70-amp-ac-current-monitor-with-iot-interface/ and still learning and working with some tutorials and documentation besides that I still need some good suggestions so that I will not face any kind of damages while working with this kind of solutions
Working With this kind solution is much newer for me and I apologize in advance if am not able to share any kind of information.
