Momentary push N.O. / N.C. For start / stop to PLC
drboom
Joined Apr 27, 2018
10
hello,
Tinkerer here. I’m using 24vdc to an input on my PLC to turn on a Servo which is currently being handled by a toggle switch.
I could just use the toggle switch to complete this But I’d like to use two momentary push buttons to handle this action; I think it looks nicer. A start(NO)and stop(NC)if you will, is a DPST relay a good option to handle this?
drboom
Joined Apr 27, 2018
10
I think I may have split your questions and answer up max
You said there would be no access to the programmer- I have a external port ran from the PLC to the outside of my little control panel which is Where I plan to put these momentary start/stop buttons. Once on and relay is in on state and the allotted time is met ( set by plc ) to the the servo get to up speed my little machine will enter a run state.
As for why I’m using hard wired logic: I just thought it would be an ok idea to have it do a simple check to the plc that “Hey the start button was hit and relay is on, user is clear go ahead and run”. And it will continue to run until I hit the stop button and relay is de energized.
MaxHeadRoom
Joined Jul 18, 2013
30,772
What I meant was that that I understood you presently had a toggle switch into the PLC which in turn controlled the servo. Not sure why you would use a toggle switch into a PLC if this is the set up.
It is a little vague as to the present set up, but if there were spare inputs to the PLC, all the logic could be done by internal logic.
Max.
drboom
Joined Apr 27, 2018
10
Max.
Ahh
The first toggle switch was really to make sure my “continuous run condition could of been met” which will now be handled by the relay
I’m not sure if there will be spare inputs. Presently yes;but if I could save an input I’m going to do so as I’m I using a lot of pneumatics with sensors and I may need more. Since this is all introductory to me I may not be doing it the most efficient way But I believe it will satisfy my needs.
MaxHeadRoom
Joined Jul 18, 2013
30,772
Sometimes you have do do things when conditions demand, but if not already aware, is to remember if you want to simulate a two posn toggle switch using a single input to a PLC is a single contact maintained P.B. or a simple on/off toggle.
Max.
drboom
Joined Apr 27, 2018
10
Max.
Nope absolutely a maintenance on off PB would’ve sufficed! But I did want two buttons one for start and one for stop. And this setup for this relay will be good knowledge moving forward for future projects who knows maybe I’ll just take the easy maintained PB route. But I do like the look of it. If I can get the code right for the plc. The “stop button” might also be a (runout / finish cycle then stop) But that is down the road.
The relay I found is NC/NC so I may not get to do it today might have to dig around or order one
Thank for the input Max
drboom
Joined Apr 27, 2018
10
What is an NC/NC relay? :confused:
The 8501kpdr12v53 relay is DPDT.
Yep sorry, got excited. I found a wiring diagram for it online
My outer casing was broke I should be able to wire it up and test it out sometime tonight. And then I’ll have my on/off buttons
Thank you
