Hi.
Both equal supply output terminals are paralleled at the front panel.
Adding 5 V to the AC secondary using the 16VAC tap instead of the 11VAC tap can bring the useable voltage to about 20VDC, enough overhead to insert pass transistors regulation to achieve 13.8 - 14 VDC
Transformer cores are 5 inch x 5 inch x 2 inch (1" x 6" ruler placed on top), have no access to center tap to separate windings and parallel them to double current capability unless damaging the wrapping. Filtering capacitors are 61000μF/50V. The relay at center delays a few seconds the inrush as 'soft start' when turning on.
The 15VDC supply unit is underused in its capability. Both transformers secondaries have 16 - 11 - 0 - 11 - 16 VAC winding terminals. Only a 0 - 11 tap section is in use at each transformer, producing 15VDC unregulated after plain 30A full wave rectifiers and filtering.Can you post pictures of the inside psu, ideally you want 13.8V for a Ham psu so a Lm7812 would do with a pass transistor..
