The circuit I posted is the same and uses a very old CA3140. It is better than a 741 or LM358/LM324 opamp but there are many better newer ones.Ok, do you know what that Op Amp in the center is, is it the CA3140?
As shown in the diagram, it converts the sawtooth output of the R/C network on the 555 to a square wave. The adjustment changes the trigger level of the op amp, which changes the duty cycle.Ok, do you know what that Op Amp in the center is, is it the CA3140?
