djsfantasi
- Joined Apr 11, 2010
- 9,237
Such contacts as you describe are not standard on a model railroad turnout. Some makes of switch machines do have extra contacts (Tortoise) while others do not (Atlas did not in the past). Various methods of controlling the switch machines would include circuitry to indicate the turnout position to make up for the lack of contacts.Hi
I know this is a model railroad turnout, but does it have contacts that indicate the position of the switch?
A real electric switch machine has position indication contacts that are used to provide feedback to the control circuit logic that the switch has actually moved to the requested position. When power is applied to the switch motor, power is maintained to the motor until it completes movement to the requested position. The actual position is then checked against the requested position before a switch position indication is provided to the operator. This type of logic check is called a "switch correspondence" check.
For what its worth...I used to design TCS/CTC systems back in the day...hope that helps.
eT
Also, model RR turnout switch machines or control might have to include contacts to power the frog of the switch.
