Model railway turn table
No nowt
Joined Mar 30, 2018
What do I need to control stepper motor and set repeated fixed position selection
What best motor and control to do job
ericgibbs
Joined Jan 29, 2010
21,555
hi No,
Welcome to AAC.
You could use a Stepper or a simple DC motor to rotate the turntable thru 90 or 180 degrees.
Can you describe the details of the rotation required.?
E
Ian Rogers
Joined Dec 12, 2012
1,136
Using a stepper gives a startup issue... The step will not be known unless there are indexes..
Unless the park positions are exactly the same distances..
There are a few 180 degree servo motors that would do the job but their accuracy isn't great.
As Eric said.. a DC motor with limit switches to park the turntable may be the best way to go... Steppers could also be used in this way..
Are you controlling with a micro??
MaxHeadRoom
Joined Jul 18, 2013
30,791
For slow applications such as this, turntables etc, a gear box is generally recommended, this makes the motor purchase more economical and reduces the torque demand on the motor by the factor of reduction.
Also greatly reduces any over-run effect when using a DC or BLDC motor.
Max.
RichardO
Joined May 4, 2013
2,270
Although a stepper motor could be used, you might not like the buzzing sound it makes. A DC motor and gearbox will be much quieter. Also, the stepper motor will need a more complex drive circuit than a DC motor.
No nowt
Joined Mar 30, 2018
Hello folks joined merg, they have a system of automation for 2nd hand stepper motor from a printer which costs
5 pounds so thanks everyone who responded
Many thanks
Allan
No nowt
Joined Mar 30, 2018
hi No,
Welcome to AAC.
E
Eric merg have a simple circuit board control for this very purpose costs a fiver
