PadMasterson
- Joined Jan 19, 2021
- 80
EETECH 00 mentioned the chip, but you might want to use the full part number to get the DIP version and not the surface Mount versions or you can't use the socket option. Looking at the data sheet, here is a snippet of that data sheet for reference.
If you order the part from a supplier, the correct part number to order is: TBD62003APG. The PG part is the DIP part shown above which you can insert in a socket. (Note the notch in the picture of the DIP version, top picture.) Pin 1 of the device is the pin closest in that view, the pin over the "D" in the "DIP16-P-300-2.54A". I was worried about including a pull down resistor but I don't think it will be needed, but if you have issues with the LED's changing state without operating a switch, it might be a good option? I was reading this thread and I'm glad EETECH00 understood all this I was lost for some time... I find it really interesting to just understand ABS signaling on the local UP main with just 14 lines, if I remember right... I hope the TS will post the final results once the system is complete.
