Hey guys,
What are the chances that I could re-program a RGB LED from ebay?
I bought a remote controlled LED lamp off of ebay.
Like this one:
http://www.ebay.com/itm/5W-GU10-Rem...310?pt=LH_DefaultDomain_0&hash=item1c15847fde
I would like to reprogram it. However, I cannot identify the microcontroller. The microcontroller is a SOIC-8. The identification is on the bottom of the chip for some reason. the chip has on it:
FC00772
AHK 1024
I'd like to find the datasheet, but I have no clue who the manufacture is. I googled a bunch, but couldn't come up with anything.
The 1024 must me the memory size?
The pinout is as follows:
1. VCC
2 Red PWM output
3. N/C. Pulled to ground with a 4.7kohm resistor
4. typical infra-red controller input.
5. 1.5vdc. square sine at 60hz, 50% duty cycle (for clock?)
6. Green PWM output
7. Blue PWM output
8. Gnd
The power supply is 120vac in, 5vdc out. It also has a 3vdc square sine coming from another lead. Not sure what this is for. Microcontroller timing?
Thanks
Like this one:
FC00772
AHK 1024
1. VCC
2 Red PWM output
6. Green PWM output
7. Blue PWM output
8. Gnd
Thanks
