Mod 433mhz module to invert output
AlbertHall
Joined Jun 4, 2014
12,663
No, not quite that simple.
It wouldn't be too difficult to make a circuit to invert the data between the receiver and wherever the data is going.
It might also be easier to modify where the data is going to accept inverted data - especially if it is a microcontroller of some sort.
Virtual Tutor
Joined Sep 8, 2018
Are you positive there is no way to adjust the op amp part of the circuit without adding components aside from maybe a bridge based on the schematic that was attached? I am trying to keep it extremely lightweight.
