mobility scooter controller-odd reverse pulses?????
Poor old sod
Joined Jul 25, 2017
193
I have noticed at very low speeds on almost flat batteries my mobility scooter seems to get a regular reverse pulse, abt every 0.5sec. I'm unsure what to make of it, unless it's some sort of speed regulation??? the machine is abt 12yo. The jerks are quite distinct and power wasting when I'm struggling to get home [due to now poor battery performance?] They're 5 mths old and fast dying, or so it appears. They just aren't big enough for my needs, so some surgery will be done to fit larger batts into the footwell, and so reduce the proportion of charge used on a normal journey. That will increase battery life dramatically. a normal journey uses 80% charge, and I need to at least halve that.
Alec_t
Joined Sep 17, 2013
15,117
Does your scooter have a forward/reverse switch separate from the speed control, or is a single potentiometer (paddle/lever) used to control both speed and forward/reverse selection? If the latter, I seem to recall some controllers use a voltage comparator to sense the pot position and hence determine if forward or reverse is commanded. An error in the comparator output as a consequence of low battery voltage could result in misinterpretation of the command.
Poor old sod
Joined Jul 25, 2017
193
Pot and paddle, but you could be right. also there's occasional brief power losses, as if wear or poor contact in the wig-wag paddle.
Poor old sod
Joined Jul 25, 2017
193
If the pot is showing signs of wear, I'd consider replacing it.
I will do that, ebay says >=$40ea sounds ridiculously high for a pot.... Seller claims dual track 3 terminal pot with 75mm shaft. need my glasses to read what's on the back of it. I doubt element14/Farnell would be that expensive.
