I am going to used the supercapacitor for energy storage. It will be used in conjunction with a dynamo generator. I am still in the process of gathering data to check the feasibility of the project.I've not looked terribly much into supercapacitors but I think the question would be how much energy they can store and how effectively they hold it. If they are simply larger capacitors then I would expect the charge to dissipate prior to the charger requiring use.
If used in conjuction with a solar cell however then they may be able to level out the dips in voltage when a cloud passes over perhaps, initial charge may take forever though.
I would like to save you time and energy by telling you battery molecules store more energy per unit than electrons in a super capacitor.I am going to used the supercapacitor for energy storage. It will be used in conjunction with a dynamo generator. I am still in the process of gathering data to check the feasibility of the project.
Do you have any suggestion?
How much does it cost if you don't mind PaulEE? I checked some sites and they have a feedback that the cost is high but the advantages they get as compared to a battery is sophistically high too.I would like to save you time and energy by telling you battery molecules store more energy per unit than electrons in a super capacitor.
And, high density super caps at moderate voltages are $$$$$.
