mobile cellphone charger circuit
sagivbh
Joined Jan 15, 2018
28
i found a mobile cellphone charger circuit with 555 timer. my goal is to make the circuit charge the phone battery to 5 volts with 2 amper, and than to stop the signal from the output(3) when the battery is charged with 5 volts. i understand that i need a lower zener diode breakdown voltage, and to change the trimmers resistance value. my first question is:
when the battery is charged with 5 volts it is going to discharge the current throw R4 R6 R5 VR1 VR2, better option is to increase their value so the current would be lower when its discharge? could this effect the 555 timer output?
second quesstion: what is the role of C1?
third question:
is there a way to add a led diode when its full charged? in this circuit the led diode goes off when the battery charged.
Thanks.
https://electronicsforu.com/electronics-projects/hardware-diy/mobile-cellphone-charger
wayneh
Joined Sep 9, 2010
18,155
Are you planning to charge a naked battery pack, or provide power to the phone with the battery pack inside? This circuit won’t work for the latter.
spinnaker
Joined Oct 29, 2009
7,830
third question:
Thanks.
Why don't you just buy a cell phone charger and save burning your house down and / or frying your phone?
sagivbh
Joined Jan 15, 2018
28
im not sure what you mean. i want it to be like any regular phone charger.
you right. i can just buy one, and it is going to be cheaper. but asking here stupid questions evantually going to teach me about electronics.
xanny
Joined Aug 12, 2017
when once voltage across pin 6 is 5.8volts, pin 3 will go low and your out put voltage will drop.........besides you will be charging your phone with about 11.5volts at the start
spinnaker
Joined Oct 29, 2009
7,830
There are lots of 555 timer projects that can be a lot of fun and are a lot safer. Charging lithium batteries is not one of them and no way to learn. Engineers with years of experience have started fires on board airplanes with lithium batteries and design fault. Please find another project.
wayneh
Joined Sep 9, 2010
18,155
There’s no such thing. Today’s chargers are able to supply higher voltage and current to devices smart enough to negotiate with the charger. The lower common denominator is plain USB, which can supply up to 100mA at 5V without any smarts. That’s a very slow charge for a smartphone. Some 5V chargers can supply 2A or more, and some devices will use that available juice, some won’t.
In all these 5V cases, the phone is controlling the charging of the battery. The charger isn’t really a “charger”, it’s a power supply with a regulated 5V and some limit to the current it can sustain. Without a charge controller (the phone), connecting it to a battery would destroy the battery, perhaps violently.
sagivbh
Joined Jan 15, 2018
28
I understand. I wont build it. Thanks for the answer.
Thanks for the answer! so today phone chargers is a power supply. So inside the smarphone charger there is a transformer with a rectifier?
wayneh
Joined Sep 9, 2010
18,155
No, they’re all what’s called SMPS, switch mode power supply. They’re much more efficient but also much more complicated.
spinnaker
Joined Oct 29, 2009
7,830
A little (big maybe) tip. If you need a switch mode supply for 12V to 5V you can use one of those cheap USB chargers for automobiles. I wish I would have thoughgt of that when I was building my solar light controller years ago.
Also depending on the chip inside your USB controller, there is a sense resistor that can be changed out to get other output voltages.
sagivbh
Joined Jan 15, 2018
28
Thanks! I will read about that.
Thanks for the tip!
