Mixed Voltage and Current source solution
SamR
Joined Mar 19, 2019
5,542
you could check your work using superposition
Thanks Al. Haven't gotten to superposition yet but am somewhat familiar with. I do like to come out of the equations with actually having equal values on either side of the equal sign though. The book does use matrices equations and spends quite a few pages explaining how to resolve the matrix both by hand and using a calculator. I save myself a lot of grief by using Microsoft Mathematics on the computer where I plug in the matrix values and let the computer resolve them nearly instantaneously. Far cry from when we had to program card decks in PL1 to solve small matrices on an IBM 360 because it didn't have enough to run Fortran.
MrAl
Joined Jun 17, 2014
13,854
You're welcome Sam.
Superposition is really easy to learn because you already know how to solve a one-source problem.
It effectively reduces multi-source problems down into one-source problems, then you just sum up all of the one-source problem results.
If you got say 1.23v from source A and 2.45v from source B, the result for that node would be 3.68v because we just added the two results. So it's like breaking the circuit up into smaller pieces so you can solve it more easily.
