Minimization POS K-Map 4-Input
33,204
What is preventing you from checking your own work? That is one of the most important skill that an engineer needs to develop.
Just work the problem backwards from your solution as though it were the problem. First, is your solution in the required form -- namely POS? If yes, then given your solution, what does the K-map look like? Is that consistent with your original map?
33,204
The point to post on the forum is to get help and have someone verify my answer. If I take the anti-derivative of 8(x+6)^2 +(8/5 +x^77) and get a solution I can just use the online derivative calculator to check if my solution was correct, but if I didn't have it I would have to take the derivative of that god-awful number. I have not found a compatible "K-Map Solver" online yet, nor am I sure on how to "check" my answer. Supply an example. If it's tedious then what would be the point of me doing it? Time is an important thing, I don't want to waste time when someone else could easily work out the problem in 5 minutes and just verify my answer.
"If it's tedious, then what would be the point of me doing it?"
How about so that you don't kill someone some day because you can't be bothered to check your own results?
As an engineer you are in the business of solving other people's problems. If they could do it themselves, they wouldn't be paying you. That's the value that you bring to the table. There often won't be someone there to verify your results -- again, if there were, they would just pay that person instead of you.
Learn to check your own work now instead of copping the attitude that your time is too valuable and that others should use up their time doing what is your responsibility.
Now, you say that you don't know how to check your own work and would like an example. That's something we can work to correct.
Let's say that you had come up with
F = (x' + y' + z)(w + x + y')
as your answer.
Let's see if that agrees with the original problem statement by working the problem backwards.
You were given a function of the form:
F = Prod(0', 1', 2', 7', 12', 15') with don't cares for 3' and 13'
and asked to find the minimal Product of Sums expression for it.
So turn that around and solve the following problem instead:
Given a Product of Sums expression, what is the corresponding expression using the Prod() notation?
Right away we run into a specification problem. Your original problem statement makes no mention of the variables {w,x,y,z} but that is what your solution is written in terms of. However, you don't say how those map to the integers that make up your maxterm values. So we are forced to guess what your mapping is (or, more to the point, reverse engineer your work to figure out that which you should have stated).
Looking at your K-MAP, this is easiest using the don't cares, which you have as follows:
||WX|||
||00|01|11|10
YZ|00|-|-|x|-
|01|-|-|-|-
|11|-|x|-|-
|10|-|-|-|-
Since your don't cares are 3' (0011) and 13' (1101), that means that your mapping must be yzwx. That seems like a very strange mapping, but that's what you are using. Are you sure it's what you meant to use?
The typical mapping would be
(msb) wxyz (lsb)
But that's NOT what you are using.
Since you didn't specify the mapping you intended to use, and since my mind reading skills aren't very good, there is no way for me to tell if you are right or wrong. Frankly, my guess is that you intended to use the more typical mapping and just made a very easy to make mistake. But if you want people to verify your work for you, you need to specify the problem well enough to enable them to do so.
If necessary, we can adjust later since it is a labeling issue, so let's keep working with the mapping you appear to be using.
Getting back to the proposed solution of
What are the maxterms that these represent?
Do you understand what a maxterm is? If not, this might be of use:
http://forum.allaboutcircuits.com/blog.php?b=583
So we want the values for which (x' + y' + z) is zero. In order for an ORing of terms to be zero, each term must be zero, which means we need
factor|y|z|w|x|maxterms|decimal
(x' + y' + z)|1|0|x|1|(1001),(1011)|9,11
Do you see what I did? If it isn't clear, ask and we can look at it step by step.
So just do this for all of the factors in your POS solution:
(w + x + y')|1|x|0|0|(1000),(1100)|8,12
So the Prod() expression that corresponds to this POS expression is
F = Prod(8', 9', 11', 12')
Comparing this to our original starting point:
we see that it does not agree AND we can see which terms we are missing and which terms we have that we shouldn't.
Notice that the K-map wasn't used at all in this process. In principle, you could start from the solution and draw the K-map and compare that to the K-map you developed when solving the problem, but that assumes that you did the first K-map correctly (which you didn't -- look at term 7). So isn't it better if we go directly from the answer back to the original problem?
Now, armed with all that, you should be able to take your proposed solution
F = (x' + y' + z')(w + x + y')(y + z)
and literally in just two minutes get
F = Prod(0' ,1' ,2' ,3' ,8' ,12' ,13' ,15')
Which you will see does not cover 7 but erroneously covers 8.
Which is better? To not waste your valuable time figuring out how to check your work and actually spend MORE time trying to find someone to do it for you, or learning how to check your work now when the consequences for mistakes are very low?
