Microphone amplifier
WBahn
Joined Mar 31, 2012
33,222
This is Homework Help, so you need to show your best effort to answer the question.
Try to reason out the answer and describe your reasoning as best you can. We can then help you confirm or refute your rationale and help you spot things you might be missing.
Сергей999
Joined Jun 9, 2022
63
Two inversions make it clear that this is a positive feedback, but due to shifts in the internal capacitances of the transistors, it can already be negative?
KeithWalker
Joined Jul 10, 2017
3,619
Note that the feedback is connected via R3 to the emitter, not the base of VT1. What difference, if any, will it make to the feedback?
KeithWalker
Joined Jul 10, 2017
3,619
Try looking at it a different way:
What happens if the signal on the input goes more positive? The collector of VT1 will go more negative because more collector current will flow through R1. That same current will flow through R2, so what happens to the emitter? What happens to the base to emitter potential when the AC feedback through C3/R4 to the emitter goes more positive, and how does that effect the collector current?
There is also a DC feedback path through R4. Did you take that into account? Is it positive or negative feedback?
Сергей999
Joined Jun 9, 2022
63
If the input signal becomes more positive, the collector current will increase, and the voltage drop on R2 will increase, this will close the base-emitter junction and the collector current will decrease. With alternating current, the same thing will happen when it passes through R2, will it close the base-emitter junction?
KeithWalker
Joined Jul 10, 2017
3,619
Yes, the same thing will happen. It will reduce the base/emitter voltage, so will that change the gain of the amplifier? Is that negative feedback?
You have looked at the feedback path through C3/R4 but is that the only thing that will change the gain of the amplifier?
What is C3 doing?
Сергей999
Joined Jun 9, 2022
63
Once the base/emitter voltage decreases, the collector current will also decrease and the gain will decrease. C3 is this negative feedback?
