microcontroller connection with main powers
Mnawer Hadid
Joined Mar 16, 2019
8
hi the system that I have consists of a microcontroller (Arduino uno), screen, motors and lamps.
how can power all of them together and connect them to power supply
cmartinez
Joined Jan 17, 2007
8,830
Are you citing the Opto22 modules?
They are nice, but limited in current rating, also if using them as a replaceable module you need to either use one of the Opto22 distribution boards or custom make the receptacle on a PCT board, which I have actually done in one case.
Also available with 5vdc input.
Nope ... I was actually referring to something like this:
ian field
Joined Oct 27, 2012
6,536
hi, im working on a project. which is unit for cell culturing process. I need to connect the microcontroller used to control the uv light and user interface with main powers.
how can I do this?/
thank you
Washing machine manufacturers routinely do non isolated front panel boards (prohibited on this forum) usually with non isolating buck regulators.
I'd suggest opto couplers for signals and small relays for power switching.
Opto couplers are simple - relays produce back emf when you switch the current off, so the MPU needs protecting - i'd recommend an external buffer transistor even if the MPU is capable of pulling in the relay on its own.
